2011 ram 1500 Front end leveling kit. And shocks do i get?
jws123
nj
I have a 2011 ram 1500 4d quad cab and my front end sits to low was looking around a different leveling kits? but idk what the best way to do it would be dont want the truck to ride like crap i did spacers with a jeep once and it was never the same. What would be a good way to lift the front end? Also one of my front shocks is bad so probably would make sense just to change them all anyone know what a good aftermarket replacement would be?
RLJ10X
Southern Indiana
You need a set of Bilstein front shocks. I think 1500 is the "model" number, but double check that. They're adjustable for height. They ride good. If you look in my sig, you'll see that's what I run in my 11. I did Bilsteins all the way around. I'm very satisfied with how my 11 looks and rides.
Look in the Lifted section. You'll find your answer there.
Check with Matt or Nick before you buy. Always good to patronize sponsors.
JB1
Houston, Texas
Is your truck a 4x4?
ThunderMug95
North Prince George, VA
2.1 on bilsteins solves your bad “shock” and will bring your truck level with little to no front droop. You can keep your stock wheels. Rear ride height does not change with adding just shocks. The ride will be firmer than stock is a negative, but the positive is that with that firmer ride comes better cornering and responsiveness.
Nick@GotExhaust
Preferred Vendor
SC
We recommend a leveling strut. Which one depends on what you do with your truck. Aftermarket UCA's are also recommended when leveling especially if you plan to off road. Message me for more info and pricing. We offer most brands and discounts for the members here!
jws123
jws123
nj
I dont offload just tired of the low look i tow with it sometimes car trailer/boat.
Nick@GotExhaust
Preferred Vendor
SC
We recommend to either swap out the UCA's when doing the leveling kit or wait until your ball joints need to be replaced. They are the week spot on the RAM 1500 suspensions especially the earlier 4th gens. New aftermarket UCA's will have more durable UCA's and also handle the angles of a leveling kit and some added travel of an aftermarket strut setup
jws123
jws123
nj
Ok ty for all the info will look up some things and post back if i have any more questions.
ram1500rsm
Trabuco Canyon, CA
I’ll do a Rancho level with their quick lift struts and rear shocks. Is basically 2” front, and all 4 corners firmness can be adjusted with a little knob to go from softer than stock ride, stock or firmer/extra firmer when you tow. I had that kit before and loved it.
jws123
jws123
nj
Been a while weather was ****** and money was lil tight but now i plan to lfit it i think i am going to do the ranco 2 inch quick lift looks like it has good reviews. Few more questions i have tho..
Anyone get any driveling vibes after lifting 2 inches? and should i do upper control arms? if so what ones? i know i have to get it re aligned after
ThunderMug95
@jws123 You dont have to replace upper control arms unless you plan on some fairly serious offroading on that 2” level. The other aspect is at a 2011 or 2012 I gather from your post you may want to get them as they should, should I say, have new balljoints which us a plus.
Mine is on a 2.1 Bilstein level over a year and no issues or evidence of added stress, but mine just sees sandy beaches and occasional dirt roads, not any legit offroading.
jws123
jws123
nj
Ok ty for the info and its a 2011 i dumped my 2012 going to go jack my truck up not even sure if my upper joints are bad yet if they are il just replace the upper arms if not i may just wait til they are bad i dont off road with it.
jws123
jws123
nj
ok balljoints and front end was tight i am actually surprised being it almost has 200k on it guess il wait til ball joints go bad to do arms
roadrnnr
Vermont
With a 2011 due to the earlier Differential you don't want to go more than 2.1. I had 2" spacers on my 2011 for 30000 miles with no problem but the Bills at 2.8 made the CV angles horrible until I put a diff drop kit in.
buddy guy
alberta
@ThunderMug95 , did you do just the Bilstein 2.1 on front or something on the back as well?
