2011 ram 1500 Front end leveling kit. And shocks do i get?
ThunderMug95
North Prince George, VA
@buddy guy 2.1 up front and then added a 1” coil spacer in rear, Bilstein 5100 and Hellwig sway bar to the rear. About 3/4-1” of rake to the front now. It really depends on the truck. Mine is a 6’4 bed crew cab, so its the longest 1500 and prob the heaviest hemi truck. A 5’7 bed crew cab may naturally sit a tad higher stock. Maybe...
jws123
jws123
nj
well i just got the rancho quick lift lil confused took old strut off installed 1 side but doesn't appear to of lifted the front and or leveled at all? maybe cause i dont have the other side on yet because ofc you know dam well the main bolt is stuck in the bushing i beat the bajesus out of it its solid even torched it so have to order new bushing. but also noticed the new strut is the same size as stock so how is this suppose to work lol?
https://www.amazon.com/Rancho-Suspe...coding=UTF8&psc=1&refRID=WESAQ9YKBZAYQFZRPQBP
jws123
jws123
nj
Anyone? that installed this kit? would like to know before i install other side case i need to return these if its just because i didnt install other side just kinda weird that its the same size as old strut idk how its made to work is spring stiffer or something so it makes it taller? lol
jws123
jws123
nj
just finished installing it did infact go up 2 inches guess it was because i only had 1 side installed truck drives and feels WAY better then stock.
blade
florida
i have the 2" rancho level struts. this is my second pair as the first set lasted over 100k miles.
i like because they r ready to install, NO SPRING SWAP. and they are inexpensive and super easy and quick to install. they r 9 way adjustable for firmness of ride as well and u can definitely tell the difference between opposing settings
jws123
jws123
nj
Welp i just sent back one of my rear shocks it went flat lol was mush apparently it appears to be common with rear socks.... the front however ride nice
