Robert Jones
2011 ram 2500 st crew long box 5.7 l gas
Troubleshooting this far
10 am fuse was blown that drove the relay coil power .... fuse location m34
swap relay. test relay on battery .. goes click.
check for continuity thru tipm ..
check wiring..
fan motor is indeed dead.. jumped the connector with alligator clips to battery. will get new one once i figure out the relay issue. see below.
however ...
the relay wont activate when i start the truck and turn on AC.
My question is what conditions need to be present to activate the relay for the fan?.. is it just AC on? or does engine need to be hot? as well?
check wiring..
however ...
