2012 5.7L Injector problems.
bentice33
Savannah, Tennessee
Hello,
I'm having problems with codes showing all 8 injectors are having circuit malfunction. P0201 through P0208. Shows Injector circuit Malfunction. Replaced ECU twice and still have the codes. When I changed the first ECU from the factory it had 1 pin corroded off causing O2 sensor problems to start. but now these injector problems. Clear codes and comes right back up with check engine light.
stevenmicheal
