2012 6.7 egr delete.
ozturkebrahem
200e
Hi guys we having a problem with egr full delete on 6.7 we have the check engine light on and car reduces power sometimes we have both programmers smarty and edge 2 but cant get ready this problem for smarty we don't have the ME files and I believe edge doesn't clear the codes truck is transporting cars and we get like 8 or 9 miles a gallon with 26k lbs weight so any help will be great does anyone has a me files for smarty
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
An Edge isn't a delete tuner so that won't do anything for you. You need the proper tune files for the Smarty and the truck needs to be fully tuned to accept the deletes. You can't just remove the EGR without running proper tuning on a 2012. And if you do fully delete it, the DPF needs to go too so you will need exhaust.
