2012 ram 2500 wiring harnesses discontinued
cowboy0495
Nebraska
6.7 cummins
Hi Benny,
I was recommended to come to you from another forum thread regarding some discontinued parts, hoping you might know some interchangeable possibilities. I have a 2012 ram 2500 6.7L, 68RFE, with the BW 44-46 transfer case VIN: 3C6UD5GL3CG293421. Transmission harness PN: 68140301AC and Chassis harness PN: 68087815AE. The transfer case blew and took both harnesses with it. I have been looking for them for a month now and Mopar claims these are the only part numbers that can work on my ram which is weird since I can usually find interchangeable parts. I was hoping you might have an idea on some interchangeable parts so I can get her back up and running. Thank you.
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Hi,
There are no dealers in the country showing any inventory and there is no direct replacement to these part numbers. I can provide you similar harness's but I would now know what circuits may be missing or extra or if the connectors would all match up. If the connectors are good on all ends you may want to consider rebuilding the harness but befre doing so have you checked salvage yards for used ones?
- Benny
C
cowboy0495
Nebraska
6.7 cummins
Every salvage yard I've found seems to cut their wiring harnesses when they remove other parts. It broke down while I was traveling in Texas so I unfortunately have to have it at a dealership instead of being able to work on it myself. The dealership doesn't want to try fixing the harness because of how tore up it was.
AllMoparParts.com
- Benny
Preferred Vendor
All
All
In that case the dealership will not want to modify any other similar harnesses I would assume.
Try using this site https://www.car-part.com/
I spent a few minutes looking for the engine harness and came up with
I didnt see a VIN but its a diesel
Pawpatrol
Tennessee
Hi Benny,
Hey Cowboy, have you located the harnesses you’re looking for?
Pawpatrol
Tennessee
