borgille
I've recently had to do some work on my truck after it overheated in January from a massive coolant leak from the oil cooler. Prior to that it had been leaking oil on the catalytic converter, which I thought was caused from the oil cooler leak, but turns out the valve cover on the right (passenger) side of the engine was leaking. I've got 90K miles on it, so I figured with the things I was seeing online about rockers and lifters failing around 100K, that it would probably make sense to replace them since I was going to all the trouble to install a new gasket. After I got it back together with the new stuff in, next day I fired it up...sounded pretty good. Took it for a 4 mile drive and when I got back, I noticed it was ticking. Worried that I got a gimp rocker in the set, I tore it apart again that afternoon and none of the rockers seems to have any play in them except for sideways movement on the valve stem. Put it back together again, and this morning, I took it for another short drive with the same result. No noticeable ticking while the engine was cool, but quite noticeable after it got warmed up. I probed around with a stethoscope -- not sure where I really need to probe -- but I checked the front and back of the valve cover, the front and back of the aluminum on the cylinder head. When the engine was cooler, there was more ticking coming from the injectors when I put the probe on the fuel rail. Truthfully, I wasn't convinced the ticking was coming from the valve area. It seemed when listening without the stethoscope than with it touching the valve cover. Attaching a couple of recordings...one near the valve cover and one from under truck where the driver seat is. Any thoughts appreciated. I'm thinking maybe I just got a set of poor quality rockers and lifters. I'll grab a recording in the morning when it's cool for comparison. BTW, not getting any codes other than P0128 for the crappy tstat that I've got to replace.
