2013-2018 RA2/VP2-NA Radio Notes
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
2017+ isn't quite plug n play like the 13-16 trucks were... still no Programming needed, but it's fairly easy. Install/add pins for the mic harness into the existing connector behind the driver side air vent, run the harness up the 'A' pillar and across the front of the headliner, cut out a 1" square opening (approx) on each side of the headliner to install the 2x Mopar Mics, plug them in to the harness and pop then into the headliner.
If you are going the uConnect 5.0" route vs 8.4, I recommend you look for a same year 4th gen ram uC5.0 as your truck (ie 19 classic, but 17-21 classic DS PN will likely be okay). Some other year uC 5.0 Ra2's can be finicky when mixed between years, exorcist the earlier ones.
M² Mods.
(via Tapatalk App)
