2013 2500 5.7 Hemi with Death Wobble
elsberndvoice
Excelsior, MN
Apologies if this has already been answered, but I have looked through the forums and have done pretty much everything that people have suggested. This is regarding an unsolved death wobble in a 2013 Ram 2500 Big Horn that I purchased for my daughter last November with only 72K miles on it last. Thought it was a great deal with the low mileage and great shape it was in at $28,900. My daughter, a Jr. Olympic equestrian, is the primary driver. We bought it to have enough power to pull a horse trailer, and installed a goose neck for the trailer she bought.
We drove it down to FL last January with no issues, and she had no issues with it in FL for the past 8 months. Before we left FL for the return to MN, a friend who is a mechanic down there replaced the rear shocks, front brake pads & calipers, and steering stabilizer bar. She also had a four wheel alignment done. On the drive back from FL to MN, we were all good until we got to Kentucky. We crossed a grate in the road on the interstate, and the truck started shaking violently. I pulled over immediately, thinking I had blown a tire on the truck or trailer. All were just fine. We now know that we experienced the dodge death wobble. Unfortunately, the mechanic we were towed to didn't recognize what we described happening as a death wobble (or had no experience with it), so he replaced the rear brakes, rotors, and calipers thinking the rear right caliper was jamming on us because the wheel did not spin freely when hoisted up and in neutral. All good for the next full day of driving, but it happened again two days later on I80 outside of Iowa City in horrible bumper to bumper semi traffic with very little shoulder. We pulled over both times, not knowing what it was. I was able to eventually get in to Iowa City, where we got ahold of a mechanic who mentioned the Death Wobble. I looked it up on YouTube and we had experienced exactly what the videos of a death wobble showed (truck in full on shakes, steering wheel shimmying violently). After doing the research, he got us in, and we looked at all of the usual suspects. Because of the looseness in so many connection points in the front, we ended up replacing damn near everything to ensure it wouldn't happen when we have a horse in the trailer:
Steering Linkage assembly,
drag bar assembly and joints,
track bar (T-type since its a 2013)
front shocks
tie rods
Four Wheel Alignment
wheel bearings and joints $4500 total (ouch!)
Got home to MN okay, and it happened again a week later even without a trailer attached, and not on rough road. As you might imagine, we are having PTSD driving the thing on any bumps. After taking it to our trusted mechanic here, he confirmed that all of the new parts were the correct parts and that they were all properly installed and tight. He suggested the only thing we hadn't yet tried that can cause it are tires.
The tires that are currently on the truck are oversized compared to what was stock. They are Goodyear Wranglers (size LT285/70/r17's instead of the OME 265/70R17s). Prior to seeing our mechanic, I had taken them in to have them evaluated by two different mechanics/tire stores and they said they were "a little off balance but nothing concerning." I have new Michelin LTX A/T 2's on the way in the original size (LT265/70/R17's). Another $1,000 investment, so we are now $7,000 into repairs with all new brakes, shocks, front end suspension and steering. Could this all have been solved with new tires to begin with or is this an everything combined thing? I am shocked that it happened again with all new parts up front, but could tires alone be the cause?
Any helpful suggestions appreciated. Thanks in advance!
Jerry in MN
OC455
Central NY
Oversize tires are a contributing factor. But you have no lift, and replaced all the major components that would cause the wobble of death. So I would think you would be good with everything. Doubt the tires being balanced correctly would have been an issue in what you experienced.
Might consider a steering box stabilizer. Probably not needed, but wouldn't hurt. Looking into one of those for myself.
You would have to find one to fit your 2500 for 2013 MY.
Burla
2010 Hemi Reg Cab 4x4
I would have suspected some of the work the first mechanic did came loose, but maybe you replaced all that. I would have just road balanced the tires as the first thing to do, I'm not sure why nobody suggested that. I guess you will find out soon enough, and yes out of balance tires can cause death wobble.
Burla
Look at the bright side, when you get new tires and no death wobble, you will have a new suspension.
E
elsberndvoice
Excelsior, MN
Thanks, @Burla. Yes, we have thought of that...should be good on brakes and suspension now (knock on wood!). We thought the same thing about some of the replaced components coming loose, but our mechanic and the second mechanic both said they were solid. The suggestion of a steering box stabilizer seems like good advice for added assurance. Looking into how much it might be to have installed.
huntergreen
Slightly off balanced tires will not cause true death wobble. I would suggest posting this in the HD section to see what other folk with HD trucks who have experienced this have done. If this were a Jeep Wrangler, I would suggest removing each component and inspect attatchment point. In other words, when each bolt is removed look at the hole for out of roundness. Each occurrence can elongate the out of roundness thus multiplying the effect Of DW. Even the new parts need to be inspected and replaced if needed. Under no circumstances let anyone tell you to put on a double shock steering dampener as this will cover up a dangerous issue until the inevitable reoccurrence happens. My best advice is to find a local Jeep club or off-road club and talk to them first hand. Most clubs know of front end mechanics that have experience with death wobble. Good luck .
E
elsberndvoice
Excelsior, MN
Thanks, @CanRebel - I have seen this before, but doesn’t promise any remedy, which stinks. The class action suit was for RAMS through 2013, and dismissed by the judge with no remedy for owners.
indept
South Jersey
Have the ball joints been replaced or at least checked for play? They weren't mentioned in your list.
Regcabguy
5.9 I-6
Dodge's are very susceptible to DW and tires, BFG KO's being the typical culprit for whatever reason. Thuren and Carli will typically ask that question. I got it one time with Toyo's no less with an extremely bad balance job by a disgruntled employee on his last day. That being said swapping the Goodyears for Michelin should solve the issue. I hope. THuren's alignment specs help with handling too.
aces2splash
Central Texas
V8
I had the same issue for my Chevy Silverado 2015 with aftermarket Fuel wheels/BFG KO's.
It would shimmy around 65 to 75 mph then smooth out at faster speeds.
I swapped driveshafts, replaced tires with the same BFG KO's, I also had my brake rotors
checked for trueness, etc. I never could figure the problem out and ultimately I traded out for my Ram Powerwagon 2021.
vernitron
5.7L
I had this issue with my JK Wrangler. I replaced the whole front end in the process of trying to fix this, except for the ball joints. I can't tell from your post if you have replaced them or not. Finally I purchased a set of Teraflex greasable ball joints and when I went to replace the old ones, the bottom joints practically fell out. Pretty much no more death wobble after that. I didn't have excessive miles on the jeep at the time, but the original ball joints were not designed for the stresses of oversize wheels.
You have to really crank down on the track bar, because if that is loose, death wobble. You might want to check where the track bar attaches to the axle and frame, to ensure the mounting bolt locations did not get ovaled out. If you have never experienced true death wobble (it is not a shimmy), you don't know what you are missing.
To be honest, that is one reason I bought a 1500 when my JK was stolen. IFS, so no death wobble, even though it is not as capable off road.
E
elsberndvoice
Excelsior, MN
UPDATE: replaced tires with all new top-of-the-line Michelin tires. Drove it for just a couple of hours before we hit the road, and it seemed to be good. Drove for 6 hours no problem and rose better than ever. Trying to drive from Minneapolis to New Jersey pulling the horse trailer, got as far as Davenport Iowa on interstate 80 (right across the highway from where it happened the second time last month), and It happened again! So, now I have all new steering kit, bearings, ball joints, track bar, steering stabilizer bar, all new shocks, and all new brakes around the truck. I am at wits end. On the road and now shopping around to try to trade it, but unsure if I should try to get anything else checked? Some have suggested U-joints, and I saw it could be the steering gear box itself, others saying it needs a steering gear box stabilizer bar in addition to the track bar and steering stabilizer bar. 6 hours from home and 12 from destination, feeling horrible. Any help appreciated.
vernitron
5.7L
One thing you could check is if the steering stabilizer is actually good or not. It is said that the SS doesn't cause the problem but my jeep sure seemed more prone to it happening when it was bad. If you can disconnect it and push the rod in and out to check for dead spots in the travel. That happened to me. I would check the torque on the track bar if that's possible. The shop may not have torqued it properly. My jeep was also more susceptible when towing my small 1000 lb camper. I guess that small amount of tongue weight was enough to unload the front and make it more susceptible. The first dealer I took mine to before I replaced all the front end parts just increased my tire pressure and that seemed to help.
RaptorHD
South Carolina
2019 2500HD
Off balance tires WILL IN FACT CAUSE THIS!
Question is, are your tires truly balanced? I see you have Goodyear tires--Hate them,, I have had alot of issues with Goodyear, if its not quality control, its flat spots or premature dry rot..
What you can do, is have your daughter get in the truck, start it up and have her rock the steering wheel back and forth about 3 inches left to right, just enough to move your drag link.. Now look at all your tie-rod ends, they should not move in the sockets,,, Watch the top and bottom ball joints at the knuckles, should not see and movement there either.. everything should be nice and tight.. If it all passes muster, I would then suspect the balance and Shock absorbers that are not suited for your truck.. If you have the generic over the counter shocks, they are not good enough..
At any rate take a look here: https://www.centramatic.com/balancers.rhtml
Now look here: https://www.centramatic.com/videos.rhtml
Watch the videos,, I run these, they work great!!
Burla
Did you get an adjustable trac bar? Those usually carry larger size and can be adjusted. If it only happened in one spot of road, maybe it is the road? Didnt happen but in one spot on road?
Yolk on driveshaft a known cause and weakness in rams, or even driveshaft itself.
Burla
some causes death wobble ram
Tracbar number one culprit, get a beefy adjustable one? Cant give up yet, you are too far in, you can fix this.
txram956
