Tryan87
I bought this truck 2 months ago with 123,000 miles and 2 weeks after purchasing it; it started to overheat. So I replaced the water pump, thermostat, coolant temp sensor and belt. The driving overheating issue has gone away but it still slowly overheats in low rpms or in idle. I've checked to make sure the fans are working, fan clutch and that they aren't weak. All good. Fan shroud fine. Fuses fine. I'm at a lose. Only thing I can think of is the head gaskets. Any other ideas before I either need to choose to replace the head gaskets or get a new motor?
