kris72079
- May 21, 2016
- 22
- 8
- Location
- Bucksport, Maine
- 2010
- Hemi 5.7
A major contributor to lifter failure and subsequent cam damage on these hemi engines (as well as with other late model manufacturers) is the MDS system. Given that you are experiencing a misfire on cyl 4 (P0304) I'd suspect that you have a component in that system beginning to fail as it operates on cylinders 1, 2, 4, & 7 if memory serves. Could be as simple as a failing MDS solenoid, although that should trigger it's own DTC or a failing MDS lifter. You can attempt to prolong the inevitable by immediately manually deactivating your MDS everytime you get in the truck or purchase a programmer to turn it off. With either option you still carry the MDS components with you. A complete MDS delete is the only permanent guaranteed solution for it to remain trouble-free.
