Dunkster71
Ok, new to this forum but I have a 2013 bighorn 5.7hemi. I went to start truck after sitting all night and it seemed to crank over longer than usual but started with no code..if I shut truck off and start it right away it starts fine and drives fine...if truck sits for an hour or so it’s back to cranking over longer but always starts...I figured it might be the fuel pressure censer so I changed it and still the same...My fuel pressure is 399kpa running and my battery is reading 14.7v running,truck shut off is 12.8v...could this be a fuel pump relay? Or a fuel pump? Thanks Dunk.
