Yes drive shaft & brackets with the 2006-2011 front carrier assembly.
East Coast Gears did mine, they also ordered new stub shafts, spacer adapter for drive shaft & hardware (bolts/washers/etc.)
If you have a 4-6inch lift or higher you will have to order brackets from lift manufacturer for 2006-2011 because stock brackets will not work unless front carrier came from same lift.
1 bracket will have to be fabricated/welded, no way around it, nothing available off the shelf as far as I know.
Existing front half axles will work, nothing needed here.
This was for a 2014 1500 5.7 Hemi Crew Cab with 6-speed.
Eco-diesel with 8-speed could be different driveshaft & bracket-wise.
Maybe someone here has done this with diesel not sure.
