Nope they're struts. You can get spacers for a decent price though. I'm gonna guess so your snow plough doesn't settle the front end down as much hey?Do the 2013 ram 1500 have front torsion bars in front?
that I can crank up about 1 inch?
thanks
Yeah I figured that's what was going on. As said above bilsteins would probly be your best bet. Not cheap but they're reliable and you can adjust what height you want. Up to 2.75 inches of lift I Beleive.Well yes I do plow this will be the fist year with this truck had a 2004 with no problems.
The blade with it all the ways up just grazes the sidewalk when backing up. The 2013 is much lower by 2 inches with no plow on truck.
When I raise the plow truck drops an inch. and with the truck being lower than my 2004 like I said it just grazes the sidewalk backing up the incline. Nothing major.
2004 had torsion bars and Portsmouth For cranked them up when i had plow put on 9 years ago.
Brandon Suppose to get snow next couple of days and I will get to try your harness.
This is Bob in Boston Ma
I'd just do fronts. You're only looking for front lift right now, I'd only replace the rear ones when they're due to be done. Easy way to test rear shocks is hop on the back of the truck get it bouncing and step off. If it bounces more than three times after you're off it needs rear shocks.Do you think I have to do all 4 shocks?
