Benbear
- Oct 23, 2017
- 2
- 0
- 2013 Laramie
- 6.7
Just had oil change , transmission service, front and rear diff, service, transfer case sevice(replace oil/filters). The tech that has serviced my unit for the past 6 yrs did excellent work. Although the same tech was promised for this work, they passed it to another tech. He did a bad job with the oil change. I supply 10 litres of my oil and then top of the engine when I get home. ..3 miles. The truck set in the garage overnite, but was level to the max mark and was a bit dirty. All past experience, with this process, was almost clear oil and add approx 1 litre. The dealership owned up to the oversight and agreed to redo the oil change and ensure the engine drained properly. Issue…I am not confident the balance of the work was completed correctly…based on a bad oil change. Can another dealership service tech inspect and confirm the balance of work was done properly? Or should I insist on a complete redo of all the work…for peace of mind? Upsets me as I reconfirmed with the service manager and advisor same tech would do the service.
