dss56
On the 2013 Big Horn on the back wall behind the rear seat how thick is the sheet metal wall. Is it single or double wall. I need to drill a hole and grommet and rtv the hole. Only a 3/8 hole to pass a cable harness with 6 wires out to the bed. I know I can go out the front fire wall where there are some larger rubber plugs then under the truck and tie wrap to areas under the truck. I'm trying to keep as much wire inside the truck as possible.
any info appreciated
