2014 3500 leaf springs
vcolper
I recently purchased a wrecked 2014 3500 HD Single wheel at an aution and need to replace the right side leaf spring as the main leaf is bent (due to the accident). I'm having a hard time finding a used one locally (Florida)
Original one on my truck reads P/N 68106102AB stamped on bottom leaf spring.
I understand these part numbers also good: 68106102AA, 68106102AB, 68106102AC, 68106102AD. Got this info from https://www.mymoparparts.com/oem-parts/mopar-rear-leaf-spring-68106102ae?c=cT02ODEwNjEwMkFD
I check everyday at the local salvage yards hoping to find one but no luck yet.
Any one here know a source for it?
Thanks
vcolper
vcolper
I recently purchased a 2014 RAM 3500 HD single wheel at an auction. I need to replace the right side leaf spring. I havent been able to find a used one locally (Florida). Plenty of the Duallys but not many single wheels.
Any suggestions where to find one? The leaf spring on my truck reads 68106102AB, but I can also use p/n's 68106102AA, 68106102AB, 68106102AC, 68106102AD, 68106102AE according to:
Thanks
vcolper
vcolper
Thanks, but I check every day at Car-Parts... none available so far. Only 5 trucks and the leaf springs are different.
Appreciate it.
vcolper
vcolper
Yes it should, How many leafs do they have?
Also there should be a part number stamped on the longest leaf towards the back.
Are you selling the set? How much and where you located?
Thanks
Arkweldr
6bt
I’ve got a set I removed from my 16 srw 4wd this summer. Yes they are for sale I’m in Arkansas .
MN-Ram
MN
6.4L Hemi
SD Truck Springs probably has one for a good price for Black Friday/Cyber Monday.
2003F350
6.7 CTD
Look for a local spring shop, there is likely one within an hour or so of you. They will build you complete new spring packs and install them, likely for less than purchasing a new set. Junkyard is always cheaper, but you don't know with 100% accuracy what you're getting or how the springs were used before you got them. With a brand new set from a spring shop, they'll be able to build them to either your existing pack OR make them heavier if you'd like.
