1 MEAN66
- Aug 20, 2022
- 220
- 212
- Location
- Waterford NY
- 2016
- Hemi 5.7 VVT-MDS
Everything made now a days has injectors. A lot of vehicle do not have "fuel' codes. Three basic thing to start any engine of any year: 1)fuel, 2) compression, and 3) spark. So from what I am reading I also agree problem sounds fuel related. Yes you say you had a good "stream" of fuel. So does a garden hose but you can squeeze the hose with your fingers and almost stop it, Fuel systems can require near 90psi, pumps are capable of more. Buy a fuel pressure gauge set, I am sure harbor freight has an inexpensive one. Test it for pressure. Once you have one you can even test for injector leaks, etc. I also believe YOU have already found the problem. Plug a scanner in crank the engine if you are getting an RPM reading then the computer knows it is cranking. You added fuel and it went VRoom. I believe you found it. It has been since 2017 since I have been full time tech but I would guess pressure with just key on will be in the 50-60 PSI range. Computer just opens and closes the injector "door" to let fuel spray, it then can also vary the time it is open (duty cycle) to vary the quantity that they actually spray. No pressure-no juice! NO juice no VROOM!
