2014 CC Sub box
chipmaker
AZ
Is there a dual sub box that doesn't affect how the rear seat sits? I have people back there all the time, don't like the idea of jacking it up.
autokraftgt
Hemi 6.1
For the record, the seat spacers are easy to install, and you will never know the difference.
But, Netaudio makes top tier subwoofer enclosures that do not require a rear seat spacer, but your airspace will be reduced
troutspinner
Gilbertsville, Pa
2019 Big Horn Crew Cab
Adding a rear seat spacer changes the height 5/8"-3/4", it is not a noticeable difference. Adding the spacers however gives you the ability to have access to the back wall which you are probably going to need to mount your amps.
You are concerned about something that does need concern.
Bkhsvt
Chicago IL
go to home depot, get some fiber glass and some resin. some Mdf and Go to town. you can build exactly what you want with no compromises
woojyee
Nebraska
Hemi 5.7 eTorque
How much experience working with fiberglass and enclosure construction do you think is necessary to make a good box on the first attempt? I have no experience working with these materials. :buffer:
ram-head
Arkansas
I wish you were closer. I'm selling my subs, box, and amp. I have a ProBox. I didn't have to use spacers with mine. They make a different style these days, so I'm not sure if that's still the case. My amp was small enough to fit between the box and the rear wall on the floor.
chipmaker
chipmaker
AZ
F' that arts and crafts ****. I have more money than time, i'll leave box building to the pros.
woojyee
Nebraska
Hemi 5.7 eTorque
LOL, I agree. If I had experience working with the stuff then maybe. I have the single stealth box with a 10w3v3-4 and it puts out some great deep bass. My buddy has the dual stealthbox I linked above. It fits in the truck and he was able to keep the folding floor on and everything. I would post some picks on his set up but he is one of my travel nurses and I sent him out of town for 2-months. :roflsquared:
He has a JL Audio 600/1v3 on them and they are loud and deep.
Bkhsvt
Chicago IL
You shouldn't need to much. More wood working knowledge really the fiberglass part isn't to bad. Just work small batches a lot of premaid boxes are terrible. And the better stuff is a waste of money
clays laramie
hemi
alternate sub boxes....
Hay all, been doing some research and cant find many box makers for our trucks... i already have a fox box and dislike it... im looking for a 1-10 passenger side box... ive looked at atrend, netaudio..... any other ideas
stevenmicheal
