2014 Pentastar Towing question
GHQ
pentastar v6
My RV weighs in at 5200lbs loaded. How will the Pentastar tow this weight. I see the 2014 towing capacity has been upgraded to 7450lbs. I only put on maybe 1000miles a year camping, other than that it a straight commuter vehicle 2 miles to work and hauling two sled in the winter at about a total weight of 1200lbs. I'm thinking the hemi would be overkill.
Thoughts?
Thankss
Droid
Pentastar V6
You need to verify that tow rating.I'm not too concerned about towing much weight, but wanted to know the limit.My salesman pulled a sheet based on my VIN from Ram showing payload, tow capacity and gross weight.My V6 2WD has 3.21 gears and my tow rating is less than 5K #.Hope that helps some.
redneckstylin
Prince George B.C.
pentastar
I agree gear ratio is a factor with the pentastar...pentastar 8spd 321 gears rated at just over 4100lbs
Sent from my GT-I9100M using Tapatalk 2
toofart
QC Canada
Hemi 8 spd
7450 towing capacity is likely for a basic, regular cab 2wd truck and a single 150lb driver, no luggage. Add doors, options, passengers and cargo, and you're up there in weight for a v6.
stevenmicheal
