Interesting. How much weight do you have packed in there? I will say that these slf140s didn't like weight. They ride very much like my bilstein coils ie SOFT just a ton longer. Almost like those tight top windings are just dead coils to take up space.
As for the relocation bracket, I actually noticed a big difference and re installed it. There are 2 other rams at work, 1 is stock, 1 is stock but a foreman truck and always loaded down to the bump stops. I took a picture of my track bar in stock position and the stock unloaded. Obviously ride didn't change, but I have a lot of really bad roads I drive exactly the same speed every day, my truck tossed and skipped in the rear much more with the relocation bracket out. Axle is within a 1/4" centered both relocated and not. I'll get an adjustable here soon, center it at ride height and be done. After I shower I'll pull my rear numbers.
I'm sure this is case to case and yoir kings dampen **** like that way more than the 5125s but it's food for thought. That being said I'm pretty sure you're sitting alot lower than me in the rear, which would make a difference.
Pics are of stock and relocated bar. I apparentally didn't take a pic of mine non relocated
Sent from my SM-N920V using Tapatalk
