revitupmoto33
- Mar 11, 2018
- 875
- 1,741
- Location
- Flagstaff
- 2017
- Ecodiesel
Thanks for the heads up bro, much appreciated.Just a heads up on the Kings.. Noticed that my tire has been rubbing the hose that leads to the resi. May want to zip tie yours back toward the chasis with a standoff.
Some info on our sway bars diameter i found in the other RAM forum, i'll leave in here in case i need to reference it
I checked my sway bars with a big adjustable wrench, i have the 20mm rear sway bar, 35.5mm front (measured right besides the bushing) so if there is only 2 front sizes, with one being 32 and the other 36.8mm, i don't have the 32mm for sure.
Do you mean the sway bar links? Apparently they had ones for the RAM but I don’t see them in their website.Just wondering if the core 4x4 sway is the same as stock size?
Yea, that's two huge benefits for sure. I need something, they are getting stupid with the amount of salt brine on the roads out here. I actually run without my fender liners so I can keep all the hard to reach spots clean.You'll love that Boeshield stuff especially if you're in the salt belt, it doesn' smell like fluid film, and it keeps anything that it toches protected for a while, fluid film is a lot thicker so it can be a mess, you spray this and use a rag to clean and shine.
King valved for the RAM, i want to see how this valving feels like first, SDHQ can valve them but i didn't want to wait, the month that went by for this things to show up felt like a damn eternity King also told me they can do free of charge as a courtesy for the first 30 or 60 days if i didn't like it, i'll take their word for it if neededAre these factory king valved, Or did you have them tuned
Sent from my SM-N920V using Tapatalk
That's Awesome! Well worth the trial and error if need be. If they already valved them I'm sure you're gonna be happy. I'm literally drooling over my phone screen at them.King valved for the RAM, i want to see how this valving feels like first, SDHQ can valve them but i didn't want to wait, the month that went by for this things to show up felt like a damn eternity King also told me they can do free of charge as a courtesy for the first 30 or 60 days if i didn't like it, i'll take their word for it if needed
Thanks for the reminder, i'll check that out this afternoon, what springs do you have?, the spring specs should be stamped in the coil, i have the 3.75X14x500, which King indicated 3.75 is the coil thicknes, 14 is the lenght of the spring and 500 is the lbs/inchYa getting everything lined up on the top end is a bit*#!! Surprised you had to cut your liner, I was able to push mine in to clear. If you are still looking to get more height mine are at 9 threads showing and still rides like a dream.
They look real good on there and I’m sure you’ll love em!
Oh ya, don’t forget to zip tie that hose back toward the frame
