2014 Ram front diff swap questions
Eforceram
Canada
First of all, sorry if this has been asked already. Ive looked everywhere and could not find the answer to my question.
So I have a 2014 1500 4X4, im doing a gear swap from 3:55 to 4:10. I already have a 2010 front diff to go in, and purchased the different front shaft as well as the different mount that is needed. I need to know if my CV axles from the 2014 will work with the 2010 front diff or will I need the other front CV axles. They are listed as different part numbers but im not sure which end of the axle is different.
The rear is straightforward enough
Any help would be appreciated or any other advice with the swap wont be discouraged.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
2014 CV axles will work with 2010 front diff........best to replace 2010 with new stub shafts if you haven't already.
E
Eforceram
Canada
appreciate it, thanks. the 2010 diff only has 40xxx km on it, the stubs are still all tight and not really worn. Any other reason to replace them? I was under the impression that these diffs really didnt have the stub shaft issues like the newer ones do.
crackerjack1957
No other reason....you can change both axles on the older front, newer ZF can only change out 1-side so if the side that can't be changed is worn you have to replace complete differential.
Some more threads on swap if you haven't already read
DILLIGAF
Canada
