Jamie9470
After cam swap codes po172 and po175 . Vacuum tester shows a steady 16 at idle, slowly increase throttle vacuum increases then returns to 16. Quick jump on throttle vacuum drops to zero makes loud rattling noise. Back at idle vacuum steady again. I'm new to this not understanding if its valve related, timing off one tooth bad rod bearing ? Any help is appreciated
