johnmwmd
With a heavy rain, I have had water accumulating on the front passenger side floor. I can tell it is coming from behind the glove box, and it shorted out my A/C module (which has been out for the past week). Took it to Safelite today, and they checked the windshield seal, and it was intact and fine. The tech did find that there was a leak where a piece of aluminum foil-type insulation is glued over a plenum (?) which is under the windshield cowl, and they temporarily fixed it with some window wrap. Water was accumulating next to the foil and leaking under it. He said he has seen this a few times before. I'm not sure what this part is called or why it is there. I only got a brief look at it before they closed it up. Can anyone shed some light on what this part is called, what kind of adhesive to use with it and what its purpose is?
