i have a 2015 ram 2500 with 6.4 hemi and the cam is bad will a 5.7 cam work? Is there anything that will interchange with it?
Where can i get a stock cam for it ?
any one have a part # ?
Thanks i found a cam now need lifters,A 5.7 camshaft is not going to be ideal in the 6.4. The stock cam is 5045517AC for the 14+ BGE (Truck) 6.4 configuration. The only other option you have is going with a custom grind, but that's going to call for an MDS delete and typically you'll also want springs and retainers depending on the cam.
http://www.modernmusclextreme.com/p-282-hellcat-hemi-lifters-by-mopar-set-of-16.aspxThanks i found a cam now need lifters,
