I have the Back-Up cam button enabled and working on my '15, unless something is different with the 2500s. Also have a UAQ and the single zone ATC.But you likely won't have a dedicated BuCam menu button.
It's because he has the 15 radio without a SW version supporting both camerasI have the Back-Up cam button enabled and working on my '15, unless something is different with the 2500s. Also have a UAQ and the single zone ATC.
The back-up cam does turn off(blue screen) if I go over 10 mph.
could i roll ack the firmware to make this work. if i go back to 17.11.07?It's because he has the 15 radio without a SW version supporting both cameras
you were correct. i disabled the cargo cam and my rear view started working but no icon for it. is there a part number for the radio i need to make them both work. i looked up used but they list these radios fitting everything from 2013 to 2017But you likely won't have a dedicated BuCam menu button.
If you ask the seller for the source VIN you can look up it up to find the model year.you were correct. i disabled the cargo cam and my rear view started working but no icon for it. is there a part number for the radio i need to make them both work. i looked up used but they list these radios fitting everything from 2013 to 2017
@Mpgrimm2 with my 2018 UAQ (that you assisted me with install ) I want to install the OEM CHMSL Cargo Cam; I already have an aftermarket back-up cam (pinned into 31 & 32 and working) and enabled CHMSL Cam in AlfaOBD (which enabled the Cargo Cam button on-screen) to allow me to access the back-up cam button and toggle between the two cam views. My question is: with an OEM CHMSL Cargo Cam, would I simply pin the cam wires into pins 24, 25, & 26 (in the t-harness) to access the Cargo Cam view? Thanks in advance! (Also, my Ram 1500 is 2014 with a 2018 radio )It's because he has the 15 radio without a SW version supporting both cameras
DO I NEED A PIN CODE TO UNLOCK A USED RADIO?Verify it by radio PN. Last 2 letters don't matter. Make sure screen is intact, and the plastic colored antenna clips on back haven't been pulled off. If from a ram... Get the vin is possible for future SW updates.
Reference: for SW & PNs.
(No, you can't roll back SW)
- INFO- 2013-2018 8.4 FW Notes (RA4/VP4 & UAx NA)
2013-17 ram, Cherokee, & viper used the exact same PN radios.
2016 RA4 VP4-NA NAV
68258671AA, AB, AK, etc
RA4 VP4-NA NAV
68270661AA, AB, AK, etc
Here's a 17 RA4 VP4-NA
2017 17 Jeep Cherokee 8.4' Uconnect Navigation Gps Display Screen 68270661AE OEM | eBay
Part # or Vehicle Model: 68270661AE. Vehicle Year: 2017. Vehicle Model: Cherokee. Vehicle Make: Jeep. Verify with dealer on Mach & Monsoon radios, and other special audio systems. Sound System Options.www.ebay.com
2016 RA4/VP4-NA
16 JEEP CHEROKEE 8.4" VP4 NA RADIO STEREO INFO DISPLAY TOUCH SCREEN 68258671AH | eBay
Part Number: 68258671AH. Removed From: 2016 Jeep Cherokee.www.ebay.com
Yes you do. Message me once you have the radio and I will assist u.DO I NEED A PIN CODE TO UNLOCK A USED RADIO?
That's correct.@Mpgrimm2 with my 2018 UAQ (that you assisted me with install ) I want to install the OEM CHMSL Cargo Cam; I already have an aftermarket back-up cam (pinned into 31 & 32 and working) and enabled CHMSL Cam in AlfaOBD (which enabled the Cargo Cam button on-screen) to allow me to access the back-up cam button and toggle between the two cam views. My question is: with an OEM CHMSL Cargo Cam, would I simply pin the cam wires into pins 24, 25, & 26 (in the t-harness) to access the Cargo Cam view? Thanks in advance! (Also, my Ram 1500 is 2014 with a 2018 radio )
