Sorry if this is in the wrong spot, I’m new here. This is my first ram, I bought it a few months ago only and this is the first real issue I’ve ran into, however possibly a big one? I looked for a similar thread and I could not find an instance quite like mine.
Was driving my 2016 1500 5.7 Big Horn today, which has just crossed over 60,000 miles, when it turned off while waiting at a stop light. The dash gave me warnings for check engine light, power steering, passenger headlight, electronic braking system, air bags, and possibly more I’m forgetting. Additionally locked me out of the radio and a red light began blinking on the dash. Even after disconnecting battery for a bit I got no crank/no start. After finding the neutral lock out and towing home I scanned the codes and got U0100, Lost communication with ECM/PCM A. I thought it may be a battery since mine was from 2019 so I bought a new one, got nothing. Tried a new 20A fuse for the ECM, I was able to start it again but it **** itself off again with the same codes about a second later. When I remove and replace that fuse I have been able to consistently start it for that 1 second. Actually, I’ve realized since I started writing this earlier, whenever I let it sit for a little while i can briefly start it as well. Regardless, it now throws a second code U1424. I looked at the connections to the pcm box and they look clean. I believe the AC dumps condensate directly underneath/next to the connections/wires, could that effect it? I’m not seeing any blatant broken/disconnected wires. I am unclear about which way to to go next. I am hoping not to have to take it to a shop/dealer and thinking that someone with more experience may be able to point me in the right direction.
If it is of any worth:
-I recently installed an amp/sub in the truck, but ran it for about a week with no issues until today. I also disconnected power from the amp when the truck initially died and have not reconnected since, and am still having the issue.
-It was a pretty hot day and my car sat in the sun for about 8 hours, but I drove for 30 minutes before the car died and to my knowledge all fluids etc. we’re still in regular operating temps when the issue occurred.
Thanks for any help you can offer!!!
