6speed4.7
Good catch on the relocation bracket boltsI hate to say it as I have not used those arms. I hope the left arm also has a mounting point for the e brake cables cause if it does your golden but if it doesn't then your ebrake mounting point is on your right arm as indicated in the photo.
In addition, I'm certain you probably have but need to Tighten up your adjustable nuts on the bars once you got them where you want them. They look loose in photo
Nice bars. Look like my cores
Doesn’t look like a lot of thread showing past the nut
The Trekline instructions provided did not have any torque numbers
I used torque amounts that varied between 130-150ftlbs, depending on wether it was a top or bottom control arm
Torquing the 16 bolts with no real leverage with limited room, on jack stands- definitely not my favourite part of the job
I also installed extra crush sleeve tubes on the bolts that weren’t included in the kit. I couldn’t get enough torque on the bolts without bending the brackets if it didn’t have the crush sleeve tube
