2016 Ram 4x4 vibration
Randy Mitchell
I have the problem that lots of people are having with vibration between 60 -70 mph, is the any help from customer care?
hemisport5.7
Canada
If it’s tires they’ll tell you warranty doesn’t cover it.
Ratket
Arizona-
Is it only at 60-70 mph?
Is it in 2x or 4x or both or one or the other? -
Slap it into neutral and does it go away?
gofishn
Iowa
hemi 5.7L, 345 cu in
had to get rid of the OEM JUnkyears and go Michelin to finally settle down the vibrations in my turck.
Good Luck.
fijicorey
Orlando, FL
Mine had a bad vibration and I had to get the tires road force balanced. It helped but it still vibrates from 60-70. I have the goodyear Sr-A tires and I'm pretty sure those are the cause. Do some research and you will find people having problems solved by replacing the stock tires.
I'm going to replace them with Michelins in the near future
Gary2
S Jersey
And you will find many more of us have changed much more than tires. Some to the point the trucks were bought back because even FCA couldn't locate the cause. I will wish ya luck and hope in your case its the tires
