2017 Leveled with 35s?
dhows31
Mississippi
I know it’s possible but is it gonna cause any issues? The only reason I’m asking is because I have a set of 35s laying around with a good amount of tread left. I am planning on running 20x10 with -24 wheels as well
RAM DRVR
Mid left coast - Oregon
CTD
You can run 35's with just a level kit on with stock rims on 2500's and 3500's and some say 1500's but I don't know anyone doing it personally..............
dmalonecentral
Tempe, AZ
5.7L HEMI® V8
I am running 35’s with stock rims on my ‘16 Big Horn with just the Bilstein 5100’s set at 2.8. No issues at all.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Yup, leveled on a 1500 you can run 35's
quietpeen
2021 TRX
Hellcat
make sure you get bilsteins and set them at 2.8. Any less an you will most likely have rubbing with that size tire and wheel combo due to the offset.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
but I can still run 35s on stock rims as long as I go 2.8?
Curlyp
OH
I have bils in the front set at 2.8” with 35” Toyos.
bigbuck92
St. Louis Missouri
6.7 CTD
I'm running 2.5 spacers here. Now I have 2.8 bils instead (better ride over stock) No issues other than a little rub full lock on the sway bar. Thats only in reverse and turning left.
Edit: These are 35 x 12.5 kendas on stock rims. These are big 35s. unlike some of the other manufacturers that say 35 and end up being 34.
bchap05
I already leveled with Bils at 2.8 and a 1.5 rear spacer as I like a bit of rake. I'm going to add a 1.5 body lift at the same time I do the 35's just to give it that extra bit of room.
bigbuck92
St. Louis Missouri
6.7 CTD
I was thinking about adding 1.5 spacers. Let me know how it works out for you. If its even worth the hassel.
Silver 6.4
Knoxville, TN
hemi 6.4
I'm also wanting to level and run 20x10 -24mm offset with 35x12.50's.
Currently has 18x9 -1mm offset with 285/65/18's and my truck appears as if it has missed leg day lol.
I'm new to the 4gen RAMS, when you guys say Bilsteins set at 2.8 do you mean buy adjustable shocks? My truck is a 2500 if that makes any dfference. Thanks guys
MADDOG
Living in a Firepit
6.4L HEMI
You can use a spacer level or some Bilsteins on the 2500's and up for those wheels and tires you are contemplating, Silver 6.4. One thing to consider, you'll probably want around 2.5" or more height increase in the front which is pretty close to the max on the Bilstein 5100 height adjustable shock.
I've never used them personally but they are quite popular. For me, a 2.5" spacer level worked out great on my 2017 2500 CTD.
Silver 6.4
Knoxville, TN
hemi 6.4
I plan on doing the 2.5 spacers up front and the shock extenders (or if someone would point me in the right direction) new/longer shocks for the front that won' sacrifice ride quality, what little there is lol
MADDOG
Living in a Firepit
6.4L HEMI
Tuff Country makes a 2" spacer kit with an integrated shock relocation bracket that preserves the steering geometry and lowers the top shock mount so you can use stock shocks with the level kit.
I used it on my 2014 2500 and had no problems. I also installed it on my 2017 2500s with no problems so far.
The part number is 32909.
Silver 6.4
Knoxville, TN
hemi 6.4
Thank you sir and Merry Christmas to you!
TEL
Chandler, Az
2009 Ram
And dont forget you may need all new gearing if you go to 35's on your truck and you want to tow anything heavy. I had to go to 4.56 gears otherwise my truck couldnt tow my trailer up the hills in the west.
shadowhawk
Southeast WI
but that's on a 6 speed gear box right?
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Not sure about -24mm offset with 35s on a 1500 I would think that would rub.
shadowhawk
Southeast WI
I thought -24 offset pushed the wheel out from the vehicle, not in.
