Most go Bilstein 5100 adjustable (up to 2.8").
to Ramforum!
to Ramforum!
Right, some folks want to use the level to remove the rake (tail high), others to clear larger tires. The great thing about these Bilsteins (5100s and their big brother the 6112s) is that they are additive to a suspension lift and often done first (usually for cost containment). As people grown into their lifts, they simply add a Zone, BDS, ProComp, Superlift, RoughCountry, etc suspension lift and can easily clear 35" and 37" tires. with up to 2.8" of Bilstein strut height on top of a 4" or 6" suspension.
It's certainly the way I went.
Yessir you can, I did just that. 3" rake from the factory. Boom, and I dropped in 305/50/20s under it to boot. Set the Billies to 2.8.
You may want to consider upgraded UCAs. Mevotec makes an improved set, or you can pull out your wallet and look at Zone. Either has a better ball joint angle than factor UCAs with Billies set at 2.8. But to be honest, I ran a year with my factory UCAs and BIllies set at 2.8 with no issues.
@FriedDumpling, first measure your rake. Measure centerline from bottom of fender to street. Subtract the front height from the back height, and you have your rake.
Get yourself some Billies and set them to that rake setting. You are now a leveled monster. We want to see some before and after pics!
You can always add a rear spacer (Tog Gunz Customs carry these) if you want to do both front and rear lift. These spacers go above the rear coils. They are cheap and effective. After that, if you want higher, get a suspension lift.
Lots of folks go Billy 5100s in the front and 5000s in the rear. It's what I did.... at first. LOL
PICS or it didn't happen. Good luck with the level!Awesome...just want to be a leveled monster. (Dream Realized)
Measure [emoji736]
Billies 5100 [emoji736]
Graduate to Middle School!
On my way!
No desire to lift yet, just level for now.
to Ramforum!
But 6112’s ride better
Yeah... but I am not allowed to say that just yet.But 6112’s ride better
So I did some research.
Looks like the 6112s offer more clearance and great for off road. I am not looking for either. Are they the right call for someone who just commutes like a regular driver and wants to level? Why?
