GlitchMobile
- Apr 25, 2020
- 13
- 0
- Location
- Montreal
- 2017 Ram 1500
- 5.7 Hemi
2017 RAM 1500, 5.7L, ~52,000 miles Continuos Overheated Mode even after parts replacement.
Hi everyone, I've replaced
Upon inspection with a temperature gun, the thermostat housing and engine were only 150F .
The dashboard display indicated outdoor temperature at 95F.
Technically the engine is not overheating (OEM thermostat opens at 203F), yet the PCM thinks otherwise.
Today (23Aug2021): cold engine 89F, reconnected the battery after 24hrs of it being disconnected.
Attempted to start the engine, but the dashboard indicates an overheated engine, even though the engine is at 89F
(Visited a nearby Chrysler dealer to ask the service/repair center, if there was a secondary thermo censor on the ram and they couldn't say.)
What could be causing the PCM to misread an overheating issue?
Is there a hidden second water temperature sensor, that works in tandem with the water temp sensor?
- the water temp sensor;
- the thermostat;
- the fan clutch;
- the oil pressure temperature sensor;
- and flushed out the entire cooling/heating and engine block system;
- Burped the air out of the cooling system after refilling;
- I've disconnected the battery overnight to reset the PCM;
- I checked all the fuses, all ok;
- tested all fuses, all functioning.
