670hoth
My 2017 1500 Express has had steering issues the last few days and the steering wheel symbol with '!' light in the dash came on today and stayed on for a couple miles until I stopped and shut off the truck at a store. It was gone when I started the truck again and I drove 20 more miles home and it never came back on again. The steering issue started as what felt like a hitch or play in the steering when you move the wheel back and forth a little bit. It seems like it also may have gotten a little worse over the few days. This afternoon I was going around a rotary and thats when the steering wheel/'!' light came on. It might have came on at the moment I turned the wheel the other way quickly to get off the rotary. I hooked up AlphaOBD and connected to the 'Steering' module and read the faults and it showed C15C1 and showed the following messages 'EPS Mechanical Performance', 'Last test completed positively', 'Error intermittent', 'Failure warning lamp 'ON': Not requested'. Also, I noticed when the truck is off and I turn the wheel there is a very slight amount of play. In an old style truck with a steering box this would easily be normal. In a truck with a steering rack I just don't know. It almost seems like the electric steering is amplifying the little bit of mechanical play at steering direction change. Please let me know what you think. Any help would be greatly appreciated!
