Reefer
Possible or may need to change the ohm setting
2018 2500 6.4L Tradesman
Changed the ohm setting and it worked all good now. Thanks!!
What was the setting that didn’t work and what did you change it to? Thanks!Changed the ohm setting and it worked all good now. Thanks!!
what happens if somebody presses the remote start while your hands are in the motor working its a safety thing. Their are no half ways to being safeAll the remote start kit comes with is the latch with a wiring harness that contains 1 wire that goes to pin 11 that tells the bcm that the hood is shut (grounded) and 2 fobs. So by grounding pin 11 you can bypass adding the hood latch and buying the skins for your current fobs you don't have to buy new one's. Had I known all of this before buying the kit I would have gone this route
2018 2500 6.4L
Disconnect the battery little hard to believe but maybe that is what you do but it would cause problems for Ram trucks with codes and relearning. Only time Ive seen the battery disconnected is if working on the electrical or gas system
I rarely disconnect the battery but it's a safe practice. Obviously if you are programming something you can't have the battery disconnected but for adding just about anything to these trucks it will have an electrical component and it's a good idea to disconnect the battery. These trucks are sensitive when it comes to anything electrical or ties into any computer. My point was short cuts are always taken and risks follow. This isn't my first ram truck and definitely isn't my first rodeo with modifying and adding factory or aftermarket parts to these trucks. I understand the risks of leaving the battery connected when touching anything on these trucks. One slip and you are praying it didn't just cost you an arm and a leg.
I was simply passing on information that others had figured out to save a few bucks. That's what the forum is about. Passing along information. Then it's up to you to decide if it's something that you want to use or find another option.
Alphaobd applies to this. Great tool but can mess your truck up if not used properly but gets offered up in just about every conversation, because it works and it's a great option for people.
And at any point the op or whomever decides to start with this option has the option to add the oem hood latch and tie it into pin 11 and have it function a 100% like it should
The 1k did not work, the 500/500 did workWhat was the setting that didn’t work and what did you change it to? Thanks!
