Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
2018 5.7 Tach fluctuating
Discussion in 'Heavy Duty' started by SouthernBubba, May 3, 2021.
  1. SouthernBubba
    SouthernBubba Junior Member
    43
    May 3, 2021
    Ram Year:
    Engine:
    5.7 Engine
    6 speed auto
    38K on the clock
    No check engine lights or any other warnings indicated
    I noticed the issue a couple of months back on a return trip from Tn not towing or any load in the vehicle . Driving on an incline 70-75 mps pushing on the accelerator and putting load on the engine it had a slight vibration but wasn't consistent . Figured maybe it was something on the road causing the vibration and didnt think much of it .
    Flash forward to today , Past few weeks I have been paying attention to the tach . Ive noticed while accelerating lightly as the tach approaches 2K needle with fluctuate (bouncing maybe 200 rpms up and down) and I can feel that slight vibration again . Oddly enough if I give put more throttle into it , the vibration and the needle fluctuations will disappear and will accelerate normally with no issues . If I take off medium or full throttle acceleration no issues . Truck pulls strong and doesnt hesitate or anything that would indicate any issues . Tires recently balanced and rotated serviced regularly . Any thoughts or ideas ?
  2. csuder99
    csuder99 Senior Member
    388
    233
    May 28, 2014
    Ram Year:
    Engine:
    Hard to say without seeing/hearing it. I'd venture torque converter clutch slipping/unlocking which can also be caused by TPS issues. Does it behave differently in tow/haul mode ?
  3. SouthernBubba
    43
    May 3, 2021
    Ram Year:
    Engine:
    I thought the same thing but will also do the same behavior in tow haul mode . I cleaned the throttle body recently hoping it would correct this issue . TB was pretty dirty , maybe clean it again?
  4. Richard Kim
    Richard Kim Member
    51
    89
    126
    Jan 23, 2018
    Houston, Texas
    Ram Year:
    Engine:
    Had the same thing happen on my 2016 2500 5.7 except it was the speedometer fluttering when I did 70 -75mph. I wonder if this is related.
  5. SouthernBubba
    43
    May 3, 2021
    Ram Year:
    Engine:
    I did a Throttle position sensor calibration (Supposedly) Turn the key to on and hold the pedal to the floor for 15 seconds ,blah blah blah . It seems to have cleared it up some or reduced it . I will know more when I take the truck to work in the morning . As mentioned earlier its more of an annoyance then it is an issue . Hell I might try cleaning the throttle body one more time . Hell Im even wondering if the tach's behavior has been there the entire time and never noticed it . I want to plug into it and check to see if any codes floating around in the system . Probably wont be able to get around to it till this weekend .
    Richard Kim likes this.
  6. SouthTexan
    SouthTexan Senior Member
    2,020
    1,104
    Jan 24, 2015
    Ram Year:
    Engine:
    408 CTD
    Might be a faulty engine crank position sensor. That is a common issue on 5.7L Hemi's in other vehicles.
  7. SouthernBubba
    43
    May 3, 2021
    Ram Year:
    Engine:
    That had crossed my mind as well . I had started googling it's location as well as places to get it from
  8. SouthernBubba
    43
    May 3, 2021
    Ram Year:
    Engine:
    Still doing it . As I said before if I keep steady pressure on the throttle while going up an incline doing 50 or so and the tach is around 2k will wobble / flutter . Same at higher speeds in upper gears. But romping on it no hesitation or anything. Would a bad crank sensor only screw up at a certain load and rpm ? Or do they just flat out fail ? Speedo is unaffected
    Sidenote: I know tachs aren't the most accurate. Just never seen one wave before at certain rpms and speeds is all. I don't remember my 1500 doing it and had the same engine and 6speed auto in it.
Share This Page
