1st of all thank you for posting the part numbers. After following the "Hard To Fill With Fuel" Diagnosis and Testing under Fueling Issues thread
https://1drv.ms/b/s!AojwsjavMvQdpniBniBO245B3Jz7?e=XnBcC1 thanks to Fast69Mopar for posting that.
I went through the steps and step 5 has you removing the large canister tube on the front of the canister or the fuel tank and try to fill with gas. I was amazed, the pump did not shut off (it actually felt strange... lol). I crawled back under the truck while at the pump and reconnected the tube and pumped more gas and within a couple of gals it started shutting off again. According to the test this means the canister is bad. I ordered the new canister online and will be replacing that BUT, I have questions.
I assume I can just brace the tank in place with floor jacks and loosen the holding straps so I can remove the heat shield since it between the straps and the tank? But is the canister held in place by clips similar to the ones that hold air filter covers in place that just pop out? I have searched the www for a video or instructions on replacing the canister but no luck (maybe I will make one).
Thanks
