I can say the deal about first is true. There is only one hill here in PA that both my 8.0l V10 Magnum and the 392 HEMI have been tamed by.
It is on route 641 between Neelyton and Spring Run. It is one of those roads where you go up to the top of the mountain to just come back down the other side. Most vehicles can not maintain the post speed limit empty let alone towing.
Going southbound both trucks can do whatever you ask. No issue and all power. They both engine brake fine going down the steep side.
Going northbound, the one switch back is 10mph and you can not recover.
My V10 is coupled to a 5speed manual. So no transmission interference at all. Going south I pull in 3rd gear and just let it lump along and have no slow down with the switchbacks. With the Hemi I select third gear and coming out od the switchbacks the truck picks second but then back to third.
Going the other way...northbound...both trucks cruise right along in 3rd gear until the 10mph switch back. I can come out of it with a 2nd gear downshift with the V10 (I have done this a few times with the V10 only once with the 392) and the Hemi stays in third...but then the Hemi slams to 1st and the V10 has to be shifted to 1st...which is a granny gear..so that is fun.
Then the magic happens. Both the V10 and the Hemi will not make the shift to 2nd. The V10 because I know it will lug down and I am not about to miss a shift...it ia along way down the side til you hit bottom...and the Hemi because the computer will not let it. And to add insult to injury...the Hemi cuts spark as you hit the redline.
So...for whatever unknown reason...the computer does protect the truck from shifting. But I think it is more because of the ungodly distsnce between 1st and 2nd.
@dhay13 knows the road I am talking about. His son got to experience it not to long ago
Now I just take the truck route out around it and never have a bad thing to say about my GAS powered Mopar trucks.
I am not so sure our 03 Hemi 2500 could make the hill.
I have talked to some with the Cummins...the guys I know have always take the truck route.
