victorj925
I have a 2018 ram 2500 powerwagon ,
Been running into an issue with what i am assuming is the axle lockers i first noticed the start of the issue when i would drive the truck and “4wd shift in progress” will sporadically/ Randomly appear on my gauge cluster soon after that i noticed that i could not get the truck to lock the front or rear axles or both. I had done some research and found someone with a similar problem and replaced the switch on the transfer case
(part # 68211454AA) and this is for the manual shift transfer case. Mine is a
BW 44-47. If this does not reslove the problem my next step was to replace the front axle actuator but still not sure if the will fix the axle locker issue or the “ 4wd shift in progress “ message. If anyone has had a similar problem or has any advice it would be greatly appreciated
Thank you
Thank you
