Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
2018 RAM Security Module Bypass
Discussion in 'M² Mods' started by DeereGuy, Aug 19, 2018.
  1. Brandon Bradford
    Brandon Bradford Junior Member
    32
    Dec 28, 2020
    Dallas, Tx
    Ram Year:
    Engine:
    3.0
    @DeereGuy
    Any idea when this will be available to order again?
    Sent from my SM-G973U using Tapatalk
  2. ripping r
    ripping r Old&Grumpy
    353
    313
    Jun 15, 2018
    earth
    Ram Year:
    Engine:
    6.4 HEMI
    Hi all. so i had to remove my buypass cable. i have to let the dealer plug in to the truck. anyway i broke one of the tabs that hold it in. thinking about just gluing it in after the dealer. i only removed it so they could connect to the pcm. i dont care if they know it was there. i guess ill just leave it in. in the future and let the stock obd hange loose.
  3. likes2build
    likes2build Senior Member
    1,082
    978
    Jun 12, 2018
    Hardeeville SC
    Ram Year:
    2018 Express RCSB
    Engine:
    3.6 Pentastar
    @ripping r I just leave it plugged in the blocks and disconnect it from the OBD connector when I go to the dealer. I plug the OEM one pack in place and tuck the bypass back up under the dash and secure it to the main wiring harness with a Velcro tie.
  4. ripping r
    353
    313
    Jun 15, 2018
    earth
    Ram Year:
    Engine:
    6.4 HEMI
    this is what im doing also. but i broke one of the tabs off when getting the obd out to put the stock one back in place. now it wont stay in place when i put back. i guess i really need a new obd port installed on the buy pass cable now.
  5. likes2build
    1,082
    978
    Jun 12, 2018
    Hardeeville SC
    Ram Year:
    2018 Express RCSB
    Engine:
    3.6 Pentastar
    Yes, I would go for the new OBD port. There's only seven wires in there so swapping it out wouldn't be difficult doing it Wire by wire.
    ripping r likes this.
  6. ripping r
    353
    313
    Jun 15, 2018
    earth
    Ram Year:
    Engine:
    6.4 HEMI
    Deereguy can i buy a new obd end for the buy pass cable?
Share This Page
