2019 1500 Classic sub
Six8888
Houston TX
Looking to see if anyone knows of a sub box that will fit. Truck has stock 8.4 Uconnect radio. Looking at upgrading speakers.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Plug and play in my 2019 Classic.
Administrator
If you don't want to lose the under seat storage, you can put a Kicker Hideaway behind the back seat.
Graygoose
Oklahoma
Convert, for now.
small
200 watt 10", plug and play, backed by Mopar as well
cam101
NC
What gray goosed has suiggested is the easiest one. I believe this is what you would by at the dealership from the parts department. The location would be underneath drivers side location in the crew cab or quad cab. The only other suggestion would be something custom made. For example in the center console or jump seat area an enclosure built there or enclosure built into the bed of the truck.
Six8888
Six8888
Houston TX
So no one knows of a sub enclosure for under the rear seat that fits other than the Kicker? I went to the link and it says it won’t fit my truck. Not sure why because it says it’s for a crew cab. I have a 2019 Classic big horn crew cab.
Graygoose
Oklahoma
Convert, for now.
small
Mine is a 2019 Classic, it will fit. I work at Kicker.
abouttobeglue
I did the kenwood powered sub, fits under the seat easily in my regular cab, easy install. Kinda wish I had put two in
Six8888
Six8888
Houston TX
For anyone interested I talked to Rhino Box here in Houston and they say their models DOG-212 and DOG-213 will fit under the rear seat. Would like to know if anyone has tried them.
Six8888
Six8888
Houston TX
You are all welcome
PowrRam
Minneapolis
2018 Big Horn
3.6L V6
Also, whatever you decide for a sub, check to see if you will lose the ability to use the fold-flat floor option.
I went with an 8" powered underseat sub that I put behind the back seat because I wanted to keep the fold-flat floor feature. There are 10" powered subs available as well.
cam101
NC
I will be putting a pair of Orion 10s in my truck this weekend. I will be using a Q bomb box.
Sent from my SM-G965U using Tapatalk
