2019 Laramie with tow package
PapaRoe
Las Cruces, NM
I’m looking at a 2019 Laramie with the tow package. Does anyone know if the larger gas tank is part of this package. I don’t see it anywhere on the window sticker, and I am not able to look under the truck, different state.
OC455
Central NY
If you have the VIN for the truck you can look up the equipment that it has:
terb
steam
the larger gas tank is an option....
Super Moderator
the option was available for that truck but OP wanted to know if the larger tank was on the truck, hence the link above to look up the build sheet.
It doesn't appear the larger tank is part of the either Tow package available for that year per the sale brochure:
grizzstang
Calgary, Alberta Canada
My 2017 has the Max Towing Package but with 20" wheels and from what I remember the bigger gas tank was an option on top of that even back then.
You would think they should go hand in had though.
runamuck
dfw
6.7 dsl
the 33 gal tank is an option. pretty cheap if you get it new..glad i have it as I tow some and it enables me to go a little farther between fill-ups. nice to see 600+ mile range when not towing.
Loudram
Just a sinner saved by grace
South Jersey
If you're looking to tow with that truck, check out the payload first. Being it's a Laramie it may have a low payload. Make sure it'll handle the tongue weight of what you'll be towing. We've all seen so many guys buy a Laramie or Limited just to realize that they have a payload below 1k.
