JamesgPW
Thanks for the info Crazy Jerry. Thuren has talked about the rubber bushings in the 19+ track bar being improved. As for the Tie Rod, there seems to be a general consensus between Thuren and Carli that the 19+ oem tie rod is on par with the Synergy tie rod for off road applications runner 37+ tires. Not sure if that is chalked up to the mounts, bushings, or the actual bar.
