JamesgPW
Is there a way to permanently disable the MDS via the computer without having to tear the head open and replace the lifters?
Will these work with the 19+? I’m told there is a bypass required?AlphaOBD
Blue Mule
Yes, with a good tuner or shop( a local shop told me) but why? If you have a 19 and you are running 91 octane (mid grade) then then the MDS will not bother you but help you gpm. ( highly debated) My wife and I separately ran a tank of gas with and without it on for a full tank and she got 321 with it off and 372 miles with in on. I got 307 with it off and 360 with it on with mixed driving. And on a long haul (3k trip) I saw 16 mpg going (off) and 18 mpg (on) returning calculating by hand.
So back in the day we would run the vehicles WOT to “blow out the carbon”. It is more “fun” to drive it like you stole it then to disable the mds. For me, I clean out the carbon at least once a month.MDS is what causes the rollers to jam up over time and grind the cam shaft lobs down. I’d rather eat some possible mpg but have an engine which lasts a few hundred thousand miles than more mpg but a bad motor at 120k miles.
Who likes math?? So the number given 120k till engine failure. 50 mpg more per tank. 310 per tank is 387 fill ups. 333 fill ups if you get the extra 50 miles per tank. So 54 tanks of gas less. So the more fuel you burn the more you fuel pump works and injectors and so on plus the cost of the 54 tanks of gas. About $3,700 in gas. Plus the other parts that go out prematurely. Net-net Zero! My opinion on the matter and risk.
But my truck will be for sale at 60k so I’m not in it for the long haul. That is why I stopped using synthetic oil. I don’t need the motor to last 100k. But you are so I did the math for you. Hope it helps even though it is not the original question.
And you didn’t even see my video from yesterday getting buried in the mud up past my tires lol...Plus not many of us buy a truck new and keep it to 120k. And if you run you truck like @IRSmart then you don’t make 50k!!! Lol j/k
Haha. You need to buy stock in HEMI!!! Only way to offset your cost on frequent purchases of engines.And you didn’t even see my video from yesterday getting buried in the mud up past my tires lol
Sorry. I will edit the post. I am running recommend synthetic 0w40 Pennzoil. I was running Royal purple.@Trailmaker What oil are you using? I believe 0w40 only comes in synthetic. 5W30?
No, mine survived this time lmaoHaha. You need to buy stock in HEMI!!! Only way to offset your cost on frequent purchases of engines.
You will possibly need a bypass cable. The 1500's do but not exactly sure on the 2500Will these work with the 19+? I’m told there is a bypass required?
