2019 Ram 1500 with P0456
aldaran
So I just hit 9,000 miles on my 2019 Ram 1500 and the check engine light turned on today. Took it to O'Reillys and it has code P0456 - Small Evap Leak. There's no more gas cap on the 2019s so what could cause this in a new model truck? It's frustrating getting a new generation truck with this issue so early. I will most likely take it in on Friday to the dealer since it's still under warranty. Any ideas what I can look at before Friday are greatly appreciated.
Tach_tech
5.7L HEMI
There’s more to the evap system then just the gas cap. Could be a leak anywhere in the evap system. Unless you want to crawl around underneath the truck and on top of the gas tank there’s not much you can do beyond making sure the top flap is closed on the filler neck.
A
aldaran
Do not get in the habit of topping off the tank after the gas handle clicks off is the best thing you cAn do to avoid these codes.
Good to know. I took it to the dealer and they did the smoke test on it and couldn't find any leak. They closed the ticket as an intermittent code and cleared it. Wasted half a day without a vehicle for this result.
dandyduo3
Orlando, Florida
5.7 V-8 Hemi
dandyduo3
Orlando, Florida
5.7 V-8 Hemi
So this happened to me over the weekend at JUST 200 Miles on my 2019 RAM 1500. Took it back to the Dealer, they checked it out and got Code P0456, EVAP EMISSIONS SMALL LEAK DETECTED. They ran all types of diagnostic tests and found nothing.
dandyduo3
Orlando, Florida
5.7 V-8 Hemi
This happened to me with the same outcome. Did it happen again?
A
aldaran
No, it hasn't happened again. Then again I haven't over topped the gas tank like I usually do. Might try it to see if it does cause the light to come back own.
dandyduo3
Orlando, Florida
5.7 V-8 Hemi
Thanks. Driving from Orlando to DC this week. Will see what happens.
Klashe123
I have a 2017 Larime and have had the same issue over the past couple years. Every time I take it in (been 4 so far) never find the issue but have replaced a couple items. Last time they replaced the Evap Canister Assembly. Will be running out of the factory warranty soon so hope this fixes the issue. Since no one ever told me about not topping off when refueling I will give that a try and hope this stops happening.
A
aldaran
Yeah, I now stop as soon as the handle clicks off and I haven't had the issue anymore.
Psul
Okc
2019 Ram Limited
5.7 l hemi
I had this code when I bought my truck with 11k miles and also had a gas odor on fill up but no leaks. Had dealer clear it first time and investigate second time. They found a broken vent tube on my fuel pump. They replaced the pump and codes and odor were and remain gone after several fill ups.
unxpctd
Minnesota
2021 PW 75A
Two things....agree with others:
Do NOT put any more gas in when it clicks off.
Second...just to be safe...turn the engine off when putting gas in. (Running into this issue with my work vehicle). I get a CEL on occasion, every month or so, if I gas up with the engine running. It clears in a day or two. I've had it checked and its the same type of CEL notice that these RAM's get. (Different brand).
runamuck
dfw
6.7 dsl
got that code and cleared it with my code scanner..has not come back. most say it can occur from over filling.
NDanecker
Earth
I constantly do 1 click after it clicks off by itself. Never had the code.
Shutting down after the first click makes sense. Since I usually pay with Credit Card there is no reason to keep fueling until ya hit a round dollar amount, and run a chance to over filling.
TinytheLaramie
FL
Not a good thing. When you go beyond the gas pump's auto-shut off and "click" some more gas into the tank, what happens is over time, fuel splashes or builds up in the vent tube that leads back to the evap canister which starts breaking down the charcoal. The broken down material clogs up the vent tubes due to the slight vacuum from the gas tank trying to pull vapors back from the evap canister into the fuel system.
NDanecker
Earth
I don't believe there is any vacuum created by the tank emptying as we have a capless filler. The tank is not air-tight, or have a valve that is a one-way vent (i.e. gas cap).
Not saying you are wrong...just wondering if what you say will happen without this vacuum effect.
Tach_tech
5.7L HEMI
There is a dual flap design in the filler neck. They are air tight otherwise they would be venting fumes to the atmosphere in a uncontrolled manner. The capless design is actually supposed to help reduce the amount of unwanted vapours being released.
The system does go into a vacuum state during normal operation, mainly during engine off times. It does this for leak testing as well. The evap system can actually be quite complex.
