Steve White
Per Chrysler and Cummings requirements: if running below 0 degrees outside, run the 10w-30 full synthetic and if above 0 degrees, it says to run full synthetic 5w-40. Oil is suppose to be drained for 40 minutes after plug is removed and do not overfill the engine!! ONLY PUT 12 Quarts of oil in and not any more!! When 12 quarts are added, THE OIL OIL IS ONLY 10 mm THE BOTTOM OF THE CRANK! If overfilled it will cause it to fill the crankcase filter and cause it to burn oil. Have seen multiple people using the wrong oil and it will make it burn oil.
I am a Dodge Tech and have been certified for over 20 years and seen what what happens to these when the right oil isn’t used. Hope this helps. The newer Cummings engine in 19 and up is totally different than the previous ones. There are very few parts that are similar.
