Big Blue Earl
Hi all,
I have a 2019 Ram 2500 gas engine that runs great, but has had leaks every 2 winters from the roof. I ended up using tons of silicone caulk all the way around the back windshield and the front windshield, as well as the center rear light (shark fin)--which, as it turned out, wasn't screwed on all the way. I also noticed very minimal glue holding down the rubber gasket at the edge of the roof, which I glued more thoroughly in the back. This caulking has solved the problem until two days ago, when, once again, water started dripping from the driver's side hand grip at the left corner of the windshield. The truck has 35,300 miles on it. Is it out of warranty?
Should I take it to the dealer to get this addressed? My own mechanic mentioned some time ago that maybe the windshield needed to be reset. I'm hoping not. I've been loathe to take it to the local dealer, since I'm afraid they will screw something else up that's currently working.
Any advice would be great.
