2020 headlight options
dchickson
Georgia
I’m a little disappointed it doesn’t have the led headlights but I would like to put some leds in it but I don’t know what my aftermarket options are
RedneckHippy
Washington
2019 Ram 3500 Tradesman
6.4 Hemi w/ MDS
I did the katana H11 off Amazon. They are bright. Only downside is the DRL uses the same lamp but at oscillating voltage, so DRLs flicker, full on headlight mode dose not flicker. I’ve read they are the same as V.4 but far cheaper. They definitely look the same. I don’t know if there is some kind of module that would fix the DRL problem, I just don’t use them.
whetrick1
You can go into settings and turn the DRL's off.
shaunnz
