Underground Lighting
Preferred Vendor
RAM has made a big lighting change. If you have a 2020-2021 RAM you may have noticed that your front turn signal socket has no wires attached to it. This makes it impossible to add load resistors to stop hyper flashing if you wanted to upgrade to LED lights. That's not the only change RAM made to this socket. They made the power and ground contacts inside the socket part of the locking mechanism and also changed the power and ground polarity. So, you will not only need a Canbus bulb with built in resistors but it also needs to be CK compatible.
Don't Worry! Underground Lighting is always one step ahead. We’ve designed a plug and play Switchback bulb precisely to adapt to these changes. They are simple to install, no resistors needed, just simply remove the old bulb and replace it with our bulb designed specifically for your 2020 RAM!
What Are Switchback LED Lights? Seen on most high-end luxury vehicles, LED stands for Light-emitting Diodes. LEDs shine brighter than any halogen bulb. LEDs create light instantly! Switchback LED lights take it to the next level. With dual filaments that allow you to change between two light colors/shades, they will enable you to switch from low-intensity parking lights to high-intensity lights.
Switchback LED bulbs are a unique way to upgrade your lighting! In a dual-filament socket, they will light up with white color as the low-filament running light, and switch to bright amber any time you hit the turn signal. When you switch the turn signal off, they'll "switchback" to white again.
To learn more or to purchase the product click the link below.
2020 Ram Switchback LED Bulbs
Here you can see a a Demonstration video of the Switchback LEDs on a 2020 Ram 1500
