Hi Leslie. Thanks! I can only speak to the shocks and the tires. I have the stock shocks (not off road Bilsteins) and so far I like the ride, even unloaded. I haven’t tried the Bilsteins, so I can’t compare. I like the KO2 tires. They are quieter and smoother riding than I expected. They are load rates E, like the factory Transforce tires. Here’s mine hitched to my TT, about 6800 pounds loaded, with 950 tongue weight, connected with a Reese WD hitch. JoeLove it congratulations
Can you give me some differences between the 2019 and the 2020 2500, if any?
I picked up my 2919 in November and it has the off-road package .... According to the manual the hill decent only works in 4 low so only usable for Rock Crawling I guess?
I bought mine to haul our new camper also so I figured the better shocks would be a nice upgrade but after having it a while (7000 miles) seems to just ride stiffer and not really benefit load carrying capacity or capability.
No RB on mine but I did build a bed slide tray so I can reach everything easily. Carried that and about 150lbs all winter in the back. Rides good this that weight but empty it is rather stiff.
How do you like the tires so far? Do you have the same load rating?
Sent from my Pixel 3 XL using Tapatalk
Nice looking truck and camper. I ordered my 2500 6.7 on March 16th. Unfortunately factories are shut down. Dealer says truck is in que and should be one of first in line to be built once factories open back up. I couldn't get the Ram boxes as they interfere with 5th wheel so I decided to go with the Tradesman. I got every option available on it and dealer is putting the 20" limited rims on it for free as they weren't an option. I couldn't pass up the deal. After taxes, tags and such out the door is only 58K.
My 2020 2500 Laramie arrived Friday March 5th, after ordering January 13th. Seemed like forever. This is my first Ram, and first post to these boards, but I’ve learned a lot lurking over the past several months. Thanks to all of you who share your knowledge. Joe
Yes, I had the dealer replace the Transforce tires with same-sized KO2s. Now I need to find a quick way to sell the Transforce to make some room in the garage. Joe
